VEHICLE IDENTIFICATION NUMBER (VIN) STRUCTURE |
POSITIONS 1- 3 WMI 1HT = U.S. PRODUCED TRUCK 1HV = U.S. PRODUCED BUS 1HS = U.S. PRODUCED TRACTOR 2HT = CANADA PRODUCED TRUCK 2HV = CANADA PRODUCED BUS 2HS = CANADA PRODUCED TRACTOR POSITIONS 4-5 ATTRIBUTES MODEL IDENTIFICATION POSITIONS 6-7 ATTRIBUTES ENGINE IDENTIFICATION POSITION 8 ATTRIBUTES GVW RANGE & BRAKE SYSTEM BRAKE SYSTEM GVW RANGE AIR HYD 0 TO 6000 A B 6001 TO 10000 C D 10001 TO 14000 E F 14001 TO 16000 G H 16001 TO 19500 J K 19501 TO 26000 L M 26001 TO 33000 N P 33001 TO 55000 R S 55001 TO 110000 T U POSITION 10 MODEL YEAR N = 1992 P = 1993 R = 1994 S = 1995 T = 1996 V = 1997 W = 1998 X = 1999 POSITION 11 PRODUCTION PLANT C = CHATHAM, ONTARIO, CANADA H = SPRINGFIELD, OHIO POSITIONS 12 THRU 17 WILL BE (6) SIX-DIGIT TRUCK JOB NUMBER POSITION 9 = CHECK DIGIT CALCULATED FROM OTHER 16 POSITIONS |
